Read More and Columns
Discussion in 'BlackBird WordPress Theme' started by suzypow, Apr 15, 2015.
  1. suzypow
    suzypow Member
    Hi there
    Website temp address is http://176.32.230.27/homesurveys.co.uk/
    2 queries.
    1) my blogs on home page have no space underneath them, and it does not say "read more", instead it displays the text, then no space and straight away the footer is there
    2) http://176.32.230.27/homesurveys.co.uk/rics-surveys/ this page I have used columns [col3][/col3] but the page is now mixed up - its after the columns where I want normal left aligned full-width text
    3) Is there a button shortcode, and I would like to insert a button in the middle of this page (mentioned in point 2)
  2. praveen
    praveen Support Staff
    Hey, Suzypow!
    Could you please provide us some edited screenshot to understand your issue and provide you the exact solution?
    In case you are unable to create a screenshot, you can follow the link http://www.screenpresso.com/ which will help you to create screenshot easily.
    Praveen
  3. suzypow
    suzypow Member
    View attachment 8025 View attachment 8026
    IMAGE 1 - Home Surveys FAQ should be on the left hand side underneath. The 3 PDF's are in [col3] to be horizontally aligned - on the same line.
    IMAGE 2 - welcome to our new website needs to have some space underneath it - it looks messy and there is no "read more"
    My 3rd question is what is the shortcode for buttons?
  4. praveen
    Hey, Suzypow!
    Please send us your website WordPress login details at [email protected] along with the thread link.
    Praveen
  5. suzypow
    suzypow Member
    Thanks, have done :)
  6. suzypow
    suzypow Member
  7. praveen
    Hi, suzypow!
    I have fixed your issue.
    Please have a look at your website.
    Praveen
  8. suzypow
    suzypow Member
    Fantastic and thanks for being so super quick!
    Is there a guide to using the short code such as the buttons? Many thanks
  9. praveen
    Hey, suzypow!
    There is no need of any guide for the short code.
    You can simply use <html> tags and apply CSS code on them.
    Praveen
