Good morning,I made a website with the theme Themia but want to make two modifications and not how. Can you help?1. On the home page, where it says "Read more ...". Put any "Leer mas" (same in Spanish).2. I removed the comments but still looks this text also want to remove: "Comments & Responses" and "Comments are closed"Attached two images for better viewing.Thank you. file://localhost/Users/Manu/Desktop/Point%201.png file://localhost/Users/Manu/Desktop/Point%202.png
1.For your first issue Go to front-page.php present in your theme directory and enter your text in place of read more..... at line number 147. Use same process for others also. 2.For your second issue Go to single.php present in your theme directory and remove the code given below Code: <h3>Comments & Responses</h3> <?php comments_template(); ?> Use same process for (page.php and template-fullwidth.php)
