"Read more" not working
Discussion in 'RoadFighter WordPress Theme' started by freedomind, Dec 5, 2013.
  1. freedomind
    freedomind New Member
  3. freedomind
    I entered a "read more tag" under the title "Equipos nuevos" in this page http://altovalleparapente.com.ar/ventas/
    I can see the <!-more-> in the html tab but it is not shown online.
    I can find the corresponding instruction in the thread provided.
    Julieta
  4. Piyush
    Put the code given below in place of your "read more tag" code.
    <a href="Enter your link url address here">Read More</a>
  5. freedomind
    I tried by using that code but I simply create a link within the document.
    My problem is that I want the content to be cut off so that it is hidden to the reader until he clicks on the "read more" .
    I usually do this with the read more tag but it does not work on my theme.
    Can you help me?
    Julieta
  6. Piyush
    You can try Toggle Box plugin for this issue.
    Download it from the link given below and install it from the Plugins panel (Plugins ->Add New ->Upload) in your Dashboard.
    http://wordpress.org/plugins/toggle-box/screenshots/
