Is there any way to change the order of the navigation menu items on the homepage? And also remove the Home button? Thank you!
Hello, You can create custom menu from your dashboard and re-arrange the menu items of your website. Just go to "Appearance -> Menu" and create a new menu. Add your menu item in that, and to change the order just drag and drop the item to its desired location and save the menu, after that select menu for your website. It will show on site. Also if you don't want to show home page then you can easily remove it from menu. It will solve your issue. Thanks & Warm Regards InkThemes.com
I am aware of how to make new menus. I was asking if there was any way to customize the built in front page menu. And if there is not the option to customize it and arrange it the way I want, is there a way to replace it completely with my own main menu specified in Appearance --> Menu?
Hello, It is not possible to replace or arrange front page but you can add an extra menu item through which will redirect you to another page. To add extra menu go to the Appearance > Theme options > General settings > Optional menu on home page.
That's a bummer because the main menu will not match the front page menu and vice versa. Creates a bit of confusion and disconnect.
Hello, Front page menu and custom menu you have created are both different. The process is: Front page menu will scroll down to there related page and also have an optional menu (To add extra menu go to the Appearance > Theme options > General settings > Optional menu on home page.) which you can redirect to the page other then front page. Custom menu will not display at the front page. Custom menu will display at the internal pages of your site. Thanks & Regards Nitesh Raghuwanshi
