Recaptcha image displaying too long on desktop and mobile versions
Discussion in 'GeoCraft WordPress Theme' started by gaamain1, Sep 19, 2014.
  1. gaamain1
    gaamain1 New Member
    The Recaptcha image is stick out past the inquiry form box being on both the desktop and mobile versions.
    Can you tell me where to find the code for each to reduce the number of pixels for the width?
    Greg
  2. Yogesh
    Yogesh Guest
    I didn't find any issue of recaptcha image, in desktop view also in mobile view.
    You can use following css code in Custom CSS to fix recaptcha image width issue, if you find.
    div#recaptcha_image {
    width: 100% !important;
    #inquiry_form #inquiry img#recaptcha_challenge_image {
    width: 100%;
    It will resolve your issue.
    Yogesh Bhade
  3. gaamain1
    gaamain1 New Member
    I tried that but got mixed results. Not sure what is causing it. Can you take a look at my site?
    http://www.bottleshopper.com
    Is my website displaying correctly on your desktop view also in mobile view?
    Greg
  4. Yogesh
    Yogesh Guest
    Your site is working fine in my desktop view, but in some mobile phone it is causing captcha image problem.
    Following code will fix this problem.
    width: 100%;
    Use above code in Custom CSS.
    Yogesh Bhade
