"Recent Posts" Widget Cutting Off Title
Discussion in 'Infoway WordPress Theme' started by lkodsmann, Apr 29, 2014.
  1. lkodsmann
    lkodsmann Guest
    When I use the "Recent Posts" widget, the title of the post is getting cut off on the right hand side... looks like a width setting may be incorrect or something. If the title is longer, it wraps to two lines - both lines are getting cut off on the right-hand side.
    Not sure how to go about fixing this...
    Thanks!
  3. lkodsmann
    lkodsmann Guest
    Here is a screenshot of the issue... You can see that the titles in the right-hand widget are cut off (the full titles display fine in the "blog" slider, though)...
    Here is a link to the site:
    http://208.76.80.11/~wwwhuman/
    Thanks!
  4. Gourav
    Paste this code in Custom CSS
     .signinformbox1.widget{
    padding-right:20px;
    Gourav Shrivastava
  5. lkodsmann
    lkodsmann Guest
    That doesn't seem to have fixed the problem...
  6. Piyush
    Paste the code given below also in Custom CSS section
    @media only screen and (max-width: 960px) and (min-width: 767px){
    .signinformbox1.widget {
    padding-right: 35px;
  7. lkodsmann
    lkodsmann Guest
    It doesn't look like that did anything, either.
  8. Piyush
  9. Piyush
  10. lkodsmann
    lkodsmann Guest
    Thank you - looks great!
    Piyush likes this.
