Redirect HTTP to HTTPS and Partially encrypted
Discussion in 'Blackriders WordPress Theme' started by mschultz33, Apr 16, 2015.
  1. mschultz33
    mschultz33 Member
    For some reason, I can not get my 301 redirect plug to work properly. I want to redirect http://example.com and http://www.example.com to my https://example.com preferred domain.
    I need help with this for both websites. valoanalliance.com and mortgagebranchconnection.com
    I installed the ssl cert through mortgagebranchconnection.com and did the add on for valoanalliance. I can do up to 5 sites through the godaddy shared ssl package.
    This is also an issue with the partially encrypt signal showing on the https.
    I have looked and researched all day and tried all the wordpress plug ins. "wordpress https", "force ssl" "redirection". Any advice would be greatly appreciated. Thank you!
  2. sameerwalkar
    sameerwalkar Guest
    We understand your concern. I can appreciate the efforts you have made to make it work. If you asked me I would rather suggest you to once consult the author of the HTTPS redirection plugins and report them about this issue may be they can guide you more correctly and based on their advice if we feel theme require some customization, then we will try to rectify it if possible.
    You can also try and go for WordPress Easy HTTPS Redirection might be it could also help you to fix the issue.
  3. mschultz33
    mschultz33 Member
    I actually got it to work, everything redirects correctly but I can't seem to fix the issue of the partially unencrypted areas. Instead of the green lock box for htttps is has the triangle in front of it in chrome. I read that sometimes plug ins may affect this but couldn't really get much information on how to fix or test things. My host said everything is set up on their end corect. Any ideas? Thanks!
  4. sameerwalkar
    sameerwalkar Guest
    Could you please send us your site URL with some edited screenshots, so that I can look into and can try to assist you accordingly.
  5. mschultz33
    mschultz33 Member
    valoanalliance.com
    I can't screenshoot anything, it's all in the address bar. Go to the website using chrome. And then click on the orange triangle next to the https and you'll see. Thanks!
  6. sameerwalkar
    sameerwalkar Guest
    I checked your site by clicking on that triangle next to https. I found something like connection uses TLS 1.2. Might be that would be creating this error. I suggest you to kindly visit the below link:
    http://support.attachmate.com/techdocs/2731.html might this can help you to sort these issue. Let me know is ti helpful or not. Hope it should fix your issue.
