Reduce heigth of slider
Discussion in 'Infoway WordPress Theme' started by bjoernjohansen, Jun 24, 2013.
  1. bjoernjohansen
    bjoernjohansen New Member
    Denmark
    Hi there,
    I would like to reduce the HEIGHT of the slider, as I think it is too dominant and pushes the content way too long down the page (http:www.bjoernjohansen.dk)
    How do I do that?
    Best regards
    Bjørn Johansen
    Paste this code in Custom CSS
    #featured .ui-tabs-panel img {
    height: 80%;
    #featured {
    height: 290px;
    Adjust its value as per your requirements.
  3. bjoernjohansen
    Denmark
    Hi Gourav,
    Thanks for your prompt reply. The above solution squeezes the picture heigth (please see enclosed) How do I avoid that? So that I can upload a file of 920x150 px and it looks great? Would a better solution be to hide the slider (I only intend to use one header) and have a static header photo? If so, how do I do that?
    Best regards
    Bjørn
  4. Nitesh
    Hello Bjorn,
    Upload image of same height that you have set in the css code.
    If you have set image height 150 then upload image of same 150px. It will resolve squeezing problem.
    If you upload single image at the slider then it will behave like a static header photo.
  5. bjoernjohansen
    Denmark
    Brilliant! Thanks
