reduce http requests by using css sprites
Discussion in 'Infoway WordPress Theme' started by satemorej, Oct 2, 2015.
  1. satemorej
    satemorej New Member
    hello Inkthemes
    is there any chance to have this done in a further release of infoway theme ?
    best regards
    Jerome
    Could you please elaborate your above words a bit more?
    And sure we will discuss with our expert team and try to implement in our next update as well?
  3. satemorej
    hello
    Looking at my Pagespeed and YSlow reports shows that my site http://www.jtsagencement.fr is quite slow due to many HTTP requests while
    loading. 16 of these HTTP requests are for infoway theme background images which are loaded one at a time.
    Combining those background images into one single image (of course far bigger) and using CSS sprite method would lead to only one HTTP request for background loading. Perhaps only one image is not realistic but far less than 16 would be very nice from my point of view.
    I hope my change request is a bit clear because as a french wood worker I am neither a professional web developper nor very good with technical english.
    best regards
    Jerome
    I would like to suggest you to install "Better WordPress Minify" plugin in your dashboard.
    It allows you to combine and minify your CSS and JS files to improve page load time.
    Here's the link of the plugin: https://wordpress.org/plugins/bwp-minify/
    Please have a look over the above link
    Also, want to suggest you to check your result through google speed test.
    Here's the link of your site details through google speed test: https://developers.google.com/speed/pagespeed/insights/?url=http://www.jtsagencement.fr/
