Reduce white space
Discussion in 'Compass WordPress Theme' started by stylize, Jan 11, 2016.
  1. stylize
    stylize New Member
    I would like to remove some of the white space if possible:
    1. I have increased the size of the slider to 421 pixel, but there is a lot of white space after the slider and before the page features.
    2. I would like to have a little less space between the two testimonials. Or even better if possible, move the second testimonial up, so they are in one line, next to each other.
    3. Remove some white space after the testimonials, before the footer widget, to move the footer widget up a bit.
    Thank you!
  3. stylize
    stylize New Member
    Hello Priyanka
    Thank you for answering.
    I have temporally turned off the coming soon, so it is visible: glifberg.dk
    .feature-content {
        margin-top: -54px;
    .feature_blog_content {
        width: 2338px;
        margin-bottom: -99px;
    Note: Change numeric value as per your requirement..
    I would also like to inform you that I have checked your site and would like to tell you that you are using 1.0.8 version of the theme whereas 1.1.0 is available in the members area..
    So if you haven't customized source code of the theme, you are kindly suggested to reinstall the latest version of the theme from the members area.
    Download the Compass theme by logging in your members account:
    Next, you have to extract the zip file and rename that folder compass like compass_new,
    Again, you would need to create a zip file of that renamed folder (say: compass_new.zip),
    Then, activate your theme,
  5. stylize
    stylize New Member
    Thank you. I will try to update the theme.
    Two more questions - Let me know if you prefer that I make a new thread for this:
    1. The Lettters in the submenu turns to a CAPITAL letter, for beginning letter of each word. We don't use that in Danish. Therefore I need to change them to small letters, for example, it has changed "Coaching for ledere" to "Coaching For Ledere" (I need to change the F and the L to small f and l)
    2. I have a picture (logo and statement) at the bottom in first footer widget area, which has size of two widgets. I would like it to resize in mobile view - now it is too big and doesn't
    resize.
    How can I make it stay the size giving in browser, but resize to fit in mobile?
    Thank you for support.
    Best regards, Heidi
  6. priya
    Regarding your first issue,
    #menu .ddsmoothmenu li li {
        text-transform: initial;
    For the issue #2, code is given below..
    img.alignleft {
        width: 100%;
  7. stylize
    stylize New Member
    Thank you for quick respond!
    The code for the mobile image worked well, thank you.
    The first question with the initial letters in menu did not work, it still shows large letter in beginning of each word when seen on computer. Is here another way to do that?
  8. priya
    Would you please try above code with "!important" as,
        text-transform: initial !important;
    And still doesn't resolve, please clear your cache and check after that...
    Hope you will find it helpful...
  9. stylize
    stylize New Member
    Hi again.
    It didn't work either with the letters. Each word in menu still has large beginning letter.
    I still have a lot of white in the right side of the frontage. Because the testimonials are underneath each other. If they can't be beside each other, I wanted to put a primary widget in the right side, next to the testimonials, but it is not visible on the frontage. How can make the primary widget visible on the frontage?
  10. priya
    Would you please send us your dashboard credentials at [email protected] along with this thread link as well so that we can figure out the issue and able to resolve that?
  11. priya
    You would be glad to know that your issue has been resolved.
    Kindly check your site and reply...
  12. stylize
    stylize New Member
    Yes, the large beginning letter problem was solved. Thank you.
    And acording to the white space on frontpage, the blog post shown can solve that. But then I want no "continue reading" or link at the features image (I have also asked for that in a mail, but didn't receive answer yet). Can I remove the links?
    I have changed the name "latest from the blog" to "Nyheder" in the from page php for now, but that should probably also somewhere in the Custum CSS with a code?
  13. priya
    Your issue has been resolved..
    And would like to inform you that there is no need to change the text in the source code, you can easily do it from Theme Option panel of your dashboard.
