Regal theme-is it possible to add more navigation tabs at the top
Discussion in 'Regal WordPress Theme' started by zahid, Nov 26, 2012.
  1. zahid
    zahid New Member
    Hi Guys
    I am thinking of using the regal theme for an interior design company.
    However I need 9 navigation tabs at the top but there are only 6 on the theme.
    Is it possible to add another 3 tabs at the top, also need to add a telephone number as well?
    I need the same look as this theme where the pics are the visual impact point.
    Or another theme option that would allow me to achieve the same effect.
    I need a look similar to this site but in wordpress http://www.pmhinteriors.co.uk/
    Any help at all would be very welcome or even if you think you could build the site.
    Zahid
