I don't know if this affects the Captcha on this theme as I have'nt had time to look properly. It may be worth looking at as if this article is valid and affects this product it may have far reaching problems when using the Captcha: https://www.wordfence.com/blog/2017...rce=list&utm_medium=email&utm_campaign=121917 Maybe someone in admin can comment. Regards,
Hi, I have got your concern and would like to tell you that the theme has an inbuilt Google recaptcha which is working properly and if you are using the recaptcha plugin then you are requested to contact the plugin author in this regard. Hope you understand this. Do let me know if you need further assistance. I will be glad to assist you. Regards, Akbar InkThemes.com
Thanks Akbar, Basically I was trying to establish whether the theme used the plugin in question or if you had taken another path. Your answer confirms for me that there is nothing of concern. Thanks,
