Regions instead of State
Discussion in 'ClassiCraft WordPress Theme' started by lucus, Aug 25, 2018.
  1. lucus
    lucus New Member
    Hi, I want to insert the Italian regions city instead of the American states. Why when I click show on the map in "insert ad" not appear on the map?
    http://www.corsidovequando.it/ad-new/
    There are other problem or customization, can i write it in this thread? Thanks a lot.
  2. lucus
    lucus New Member
    Hi, can someone help me to solve the problems of my site? Thank you.
  3. akbar92
    You can make the use of Advance Location Field feature in this regard.
    To enable it, Go to (Dashboard->Settings->Advance Settings->Custom Fields). Just follow the attached screenshot.
    Yes, you can write it here. You can also email us at [email protected]
    Akbar
  4. lucus
    lucus New Member
    Hello, I've already disabled the advance location field. I've set the fields Regions, City and Address(optional) and i want show the location when the users click on "show on the map" (see attached image). In regions the field "Seleziona" must be non-selectable.
  5. lucus
    lucus New Member
    The problem is this... var address = street + ', ' + city + ', ' + zipcode + ', ' + state + ', ' + country;
    I need only street+city+region of italy(that you call state in multiple selector). In in homepage search i need the search only for region(abruzzi, basilicata) or city. Unfortunately, your themes are for all the states of the world, but I'm only interested at Italy
  6. akbar92
    Thanks for reaching out to us again,
    The possible way you can edit states, just follow this video: https://screenpresso.com/=rdTDg
    I hope this was purposeful for you.
    Akbar
  7. lucus
    lucus New Member
    Hello, editing the state field the others remain active(continent and nation).
    See attached image.
  8. akbar92
    You are requested to disable Advance Location Field feature to remove those fields.
    To disable it, Go to (Dashboard->Settings->Advance Settings->Custom Fields).
    Hope you find the above information purposeful to you.
    Akbar
