Hi, I am a monthly paid-subscribed member of yours. I am using BlogSpring for one of my project. I just noticed that the "Related Posts" section on single post (single.php) does not appear. Could you kindly check and tell me if I need to do something different or how does it work? For your reference here is the site: http://www.iqaamah.com/ And here is a single post: http://www.iqaamah.com/prophet-muhammad-صلى-الله-عليه-و-سلم/ If you scroll down all the way to the bottom where it says "Related posts", its empty. Thank you.
Hello, Greetings from InkThemes! Would you please reinstall the theme and check after that.. Here're the steps of doing so... Download the BlogSpring theme by logging in your members account: http://inkthemes.com/members/member Next, you have to extract the zip file and rename that folder blogspring like blogspring_new, Again, you would need to create a zip file of that renamed folder (say: blogspring_new.zip), Now, upload the theme in your WordPress from Dashboard->Appearance->Themes->Add New, Then, activate your theme, This way you can install and activate your updated version in your site, keeping the copy of your older version in your WordPress Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hi, Thank you for getting back to me. Unfortunately the above instruction did not resolve the problem. Please reply. Thanks.
Hello, I have checked your site and would like to inform you that everything is just fine over there... Kindly check the screenshot given below.. Hope you will find it helpful.. Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
