Hi there. I am stuck as to how to remove "About us", "What Our Clients say", and "Services" sections on home page. I have tried to place text widgets on the Secondary widget area and Home Page sidebar widget area with no result. I have downloaded the Front-Page.php document with no result. please inform the best way to remove this. i have placed the following code in the css styling optionsnwith no result 9although it did remove the facebook section): .bottom_footer_content .social_logos { display: none; } .home_content { display: none; } .feature_testimonial { display: none; } Please help. this is driving me mad. thanks Anne
_________________________________________________ Its ok, something has happened, and these area are no longer visible.... thanks Anne
Hello ! You can remove all by default widget by using blank text widget on widget area if you don't want any widget. let me know for further doubt and queries. Thanks & Regards Pramod
Hi, I just purchased traffica Pro and i am stuck with the same probleme. I have removed all the widgets but i am unable to edit the sidebar footer. How to remove it ? Thanks
Hello medbrasil! Plese go to appearance=> Widgets=>Drag any widgets on First,Second,Third,Fourth footer widget area. If you don't want any widget then you can use blank text widget here. Or you can remove them by CSS. Thanks & Regards Pramod Patel
