I have two Posts I want to remove the Author's and Category names on, but I want the rest of the Posts to remain as is (showing the information.) Is there a way to do that? Thanks
Hello, Through post id selector you can apply css style code only for specific posts. Firstly go to the Posts> All Posts in your dashboard and hover the edit option of that post from which you want to remove the Author's and Category names and copy its post-id number. See the image for reference Now, add that post id in the css code given below( current post id is 412) after that paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .postid-412 .post .post_meta .posted_by { display: none; } .postid-412 .post .post_meta .post_category{ display: none; } This will solve your issue.
