Remove Box and underline on pages
Discussion in 'StartPoint Business One Page WordPress Theme' started by ianharv, Jun 13, 2016.
  1. ianharv
    ianharv New Member
    Hi, I've got a page on the full width template and a box sits around the content - can I remove this? or at least change the colour?
    Also, there is an underline across the page under the title that I'd like the option of removing.
  3. ianharv
    ianharv New Member
    Hi Priyanka,
    We fixed this in the CSS in the end so no need.
    I do have one other question though - menu items are separated by a '/' - where would I go if I wanted to change this to a '|' instead?
  4. ianharv
    ianharv New Member
    ...and also, with the three column feature, is there a way to make each individual box linked, rather than just the title?
  5. ianharv
    ianharv New Member
    Hi, are you able to help?
  6. priya
    Please send us your site URL..
  7. ianharv
    ianharv New Member
  8. priya
    To replace '/' tag
    To make each individual box linked..
    Screenshot is given below..
    ianharv likes this.
  9. ianharv
    ianharv New Member
    Thanks!
