Hello, I'm using the Land Owner/Broker Pro version of the Butterbelly Theme. I would like to REMOVE the three circles and the images inside each circle. Is that an option or does it require custom CSS? If custom CSS is required, please send me the code. Thanks!
Hello, Thanks for getting back to us, To make the desired changes, just paste the code in the Additional CSS section of the theme. Go to (Dashboard->Appearance->Customize->Additional CSS). Code: .feature-content .feature-content-inner .feature-content-text .circle img { display: none; } Regards, Akbar InkThemes.com
Hello, Greetings from InkThemes, You are most Welcome! If you need further help then just let me know, I will be glad to assist you. Regards, Akbar InkThemes.com
