Remove dashes above footer
Discussion in 'Andrina WordPress Theme' started by remleysenior, Apr 18, 2014.
  1. remleysenior
    remleysenior Guest
    How do I remove the dashes above the footer? I'm not using homepage two columns and I want to remove the separator since it's no longer serving a purpose. I've tried to follow the example for remove dashes from under the slider but wasn't able to figure out what class was being called for the homepage two columns.
    Could you please specify your issue with the help of screenshot images that which dashes you want to remove and also share us your website link
    so that we can provide you exact solution.
