Remove Default Navigation Menu?
Discussion in 'BlackBird WordPress Theme' started by ashybaby87, Sep 1, 2013.
  1. ashybaby87
    ashybaby87 Member
    I was testing out some themes and decided I wanted to stick with the blackbird theme. I went to activate it again and my custom menu of course didn't revert back to what I had it set on, probably from fooling with other themes. Anyway, I wanted to remove the default navigation menu (refer to image, I want to remove the circled area). I have a custom menu but when I used the code
    .menu_wrapper{
    It actually takes away your menu as well as my custom one. I just want it back to normal again. Please help!
    Screen Shot 4 is how my screen looks now, screen shot 5 is what I'm trying to get it back to if it helps make things clear.
    Thank you in advance for your time.
  2. ashybaby87
    ashybaby87 Member
    I believe I resolved the problem. I removed this code:
    <?php inkthemes_nav(); ?>
    from my header.php and all looks normal again.
