How can I remove the general animation on the front page? I still want the slider to rotate, but don't want the feature boxes to scroll up (as well as other animation on the page). Thx.
Hello, Greetings from InkThemes, To remove the general animation on the front page, you need to remove the animate.css file from your website and put comment tag in the function.php file, just follow the attached screenshot. First, install and activate the AceIDE plugin then select function.php file from the AceIDE editor. https://screenpresso.com/=Qqbqb Hope this helps...! Thanks & Regards! Akbar InkThemes.com
Thank you for helping us remove the animation, but how would I remove the grey box in general? The box that the animation pops out. It is hard to read text on the box and would like to remove it in general.
Hi, It would be better for us to understand your query with the help of some edited screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you. Looking forward to hearing from you soon. Thanks & Regards! Akbar InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
