Is it possible to remove "home" from the Third and Fourth Footer Widget Area? http://test.aangepastwonen.info/ Thank you.
Hello Maggiemae, Yes ,It is possible to remove "home" from the Third and Fourth Footer Widget Area. For this purpose , 1. You should have to create a custom menu from the menu option . 2. Then You should have to select pages for the custom menu, at this time do not select the home page. 3. After creating the custom menu then select newly created custom menu. kindly refer attached screen shots for more help. Thanks & Regards! Ankur Jain InkThemes.com
