remove home page features
Discussion in 'ButterBelly WordPress Theme' started by vesity, Aug 9, 2014.
  1. vesity
    vesity Member
    Hi. This is a request which I discussed with your sales dept prior to purchasing the theme, and they confirmed you can do it for me.
    I want to remove the "homepage feature area" and the "home page bottom feature," and then replace that with the contents of the blog page.
    In other words, The home page would consist of the slider at top (unchanged), but then immediately under the slider would be the blog... Just exactly as it looks on the "blog page" (two columns of blogs on left, and sidebar at right). Then the bottom would be the footer, unchanged.
    Grateful for your help!
  2. Yogesh
    Yogesh Guest
    If you want to delete homepage feature area and home page bottom feature you need to delete some code from front-page.php file.
    Go to the
    wp-content\themes\butterbellytheme\front-page.php
    and delete code from line no. 244 to 394.
    Or you can just hide those features by simply adding this code in Custom CSS
    Go to -- Appearance > Theme Option > Styling Option > Custom CSS
    .feature-content,.feature_mid_content {
    Yogesh Bhade
  3. vesity
    vesity Member
    Thank you. Ok that's great. But as to the second part of my question... I want to have the blog page immediately under the slider. From my previous post:
    "The home page would consist of the slider at top (unchanged), but then immediately under the slider would be the blog... Just exactly as it looks on the "blog page" (two columns of blogs on left, and sidebar at right). Then the bottom would be the footer, unchanged."​
  4. Pramod
    Pramod Guest
    .feature-content
    Pramod Patel
  5. vesity
    vesity Member
    Thanks for your response. But it doesn't resemble the blog page, it just brings the blogs from below up to beneath the slider.
    Again, what I need is the blog page to start immediately under the slider. Two columns of blog postings on the left, and the sidebar on the right.
    So, just to restate what I said in the first post of this thread: This is why I purchased this theme.
    If you check the Formget archives you'll see my detailed question about this prior to my purchase, and your detailed answer, saying that, yes, you can do it, no problem.
    Thanks for your help.
  6. Pramod
    Pramod Guest
    Hello ,
    We have got your concern, please send us your WordPress dashboard login details also the link of this thread at [email protected]. so that, we can have a look over the issue in details.
    Your website link:
    WordPress username:
    WordPress password:
    Pramod Patel
  7. vesity
    vesity Member
    Thank you. I will send it.
  8. Pramod
    Pramod Guest
    Please visit your website.
    Pramod Patel
  9. vesity
    vesity Member
    Looks fantastic, thank you!! Are there any particular settings you changed that I should be aware of, so that I don't accidentally undo what you've done?
  10. Pramod
    Pramod Guest
    Please don't bother about undo. We made some changes on front-page.php and css files.
    Download your theme with the help of wp editor plugin. If you will face any problem in future it will help you.
    Pramod Patel
  11. vesity
    vesity Member
    Thank you!
