Remove Lead capture and add fullwidth text
Discussion in 'Infoway WordPress Theme' started by chrisanscombe, Nov 15, 2013.
  1. chrisanscombe
    chrisanscombe New Member
    I can remove the lead capture box by adding a text widget but is there any way of replacing it with a full widthe text box instead?
