I am using Slider 1 & 2 and would like to remove READ MORE or change to white so invisible http://couragetotransform.com I notice you have answered this before but send out a file to make the change. Thank you
Hello, Paste this code in Custom CSS Appearance > Theme Option > Styling Option > Custom CSS Code: .flexslider .slides span { display: none; }
Great! One more question. I am just using the Slider Heading Area so on Slider #1 if I leave it blank it puts in default text. I entered a "." which is not a bad solution but can I just have it left blank? Thanks.
Hello, Go to Appearance > Theme Option > Slider Settings > First Slider Heading and add paragraph text there. For example Code: <p></p> Use same process for others also.
