Remove recently added and categories from front page
Discussion in 'GeoCraft WordPress Theme' started by chriskx, Aug 14, 2015.
  1. chriskx
    chriskx New Member
    I would like your help with the following 2 queries regarding the new geocraft v2.03:
    1) I'd like to hide the recently added listings from the home page
    2) I'd also like to hide the categories side bar from the home page
    Thanks in advance
  2. nitin
    nitin Guest
    Fixing these issues are really easy.
    Please follow the video link given below: -
    http://screenpresso.com/=fcf8d
    Nitin
  3. chriskx
    chriskx New Member
    Hi Nitin,
    I did exactly as the video showed. The category part is now hidden but the recent listings has remained despite having deleted it.
    Any other ideas?
    Thanks in advance for your help
  4. nitin
    nitin Guest
    Sorry to learn that you are not completely out of the issue.
    As an alternative to this, now we have to do customization of your website at our end.
    So, send us your website WordPress login details at enquiry@inkthemes.com along with the thread link.
    Rest assured and thank you for your patience.
    Nitin
  5. chriskx
    chriskx New Member
    Any idea what code needs to be removed from the frontpage?
    thanks in advance
  6. nitin
    nitin Guest
    If you want to edit/alter the code at you end, you can do it easily.
    All you just need is to add '<!--' and '-->' to the start and ending section respectively of the area you wish to hide.
    http://screenpresso.com/=AasJd
    Nitin
  7. chriskx
    chriskx New Member
    Thanks Nitin for all your help. Problem Resolved!
  8. chriskx
    chriskx New Member
    The Geocraft 2.03 zip file is missing the "templaye_search.php" file. Search results are not showing now. Any solution?
  9. nitin
    nitin Guest
    Could you please tell me what issue you are facing (if any)?
    The file you are looking for named as 'templaye_search.php' is no-where in the theme. For searching functions, we use a different file for functionalities.
    Explaining me the issue could help getting it resolved in a better way.
    Nitin
