Remove "Recently Added" Code Caused Issues
Discussion in 'GeoCraft WordPress Theme' started by rdeshazer, Jan 9, 2016.
  1. rdeshazer
    rdeshazer Member
    USA
    This code did remove the the "Recently Added" section from the Homepage, however it caused some other issues in removing it from all locations which is not what I wanted.
    .featured_content {
    display: none !important;
    1. When you search a business for example (Cutz) or any business listing and no search results are displayed.
    http://www.squirrlit.com/
    2. When you select "All Listings", "Recently Added" results no longer appear.
    http://www.squirrlit.com/all-listing/
    3. When you select "Premium Listings", "Recently Added" results no longer appear.
    http://www.squirrlit.com/featured-listing/
    4. When you click on a listing from the "All or Premium Listings" results and the "Map" is missing.
    http://www.squirrlit.com/listing/the-quality-hotel-wembley-london/
    * So is it possible to remove "Recently Added" section from the homepage without it being removed from the other pages and or affect the other pages functions\layout?
    * Also is it possible when removing "Recently Added" section from the homepage, thereby performing a search, the results will show up below the blakc divider line on the homepage?
  2. rdeshazer
    rdeshazer Member
    USA
    Thoughts?
  3. priya
    For your first issue.
    Please follow the screenshots given below.
    For you second issue, which was related to the search, you are kindly suggested to reinstall the theme and check after that...
    NOTE: And let me clear you that map will show only for the premium listings not for the free listing..
  4. rdeshazer
    rdeshazer Member
    USA
    Please DELETE this threat, the information above did not fix the issue and cause more problems, I do not want other users to try the above solution. I will create a new threat with pictures and hopefully a more descriptive explanation of my issue. Just as an FYI the above numbers and tags didn't match your illustration.
    Thank you.
  5. priya
    Hello Rdeshazer,
    I have checked above solution and it works perfectly at our end and really not getting why it didn't work for you..
    But still I have replied you at another thread link regarding this issue and all the other issues as well..
    Kindly check.
