Remove Scroll to Top Icon
Discussion in 'One Page Pro WordPress Theme' started by evanjf92, Jun 28, 2016.
  1. evanjf92
    evanjf92 New Member
    FLORIDA
    Hi Inkthemes,
    I wanted to know if it is possible to remove the Scroll to top icon that appears when you scroll to the bottom of the page? For some reason, scrolling down the page with the mouse wheel does not work so, I am using a plug-in to fix this issue. What part of the code should I remove to fix this issue without breaking my webpage?
