Hi, Have a problem. Need to remove the side menu on http://www.fokuspharma.se/educations/categories/kategori-1/. Tried to removing the code in the page do not make any diffrence. Which code should be removed? Thanks!
I dont want side bar in any page, catergories, blog, single page etc. I there any possibility to "turn it off". Any masterswitch coding?
Hi Pharma, Please follow the screenshot. While creating a page select fullwidth template. You can use this code to remove sidebar. Code: .sidebar { display: none; } Thanks Praveen
Hi Praveen, Problem is that for example http://www.fokuspharma.se/educations/categories/kategori-1/ does not have any admin page in the admin panel. I think I need a CSS code to remove the sidebar in categories pages.
Hi Pharma, Please follow the link given below http://www.inkthemes.com/community/threads/remove-sidemenu-in-categories.15362/ Thanks Praveen
