Remove Slider Heading and Description on first slide
Discussion in 'ColorWay WordPress Theme' started by rlculver, Nov 30, 2014.
  1. rlculver
    rlculver New Member
    Is it possible to remove the slider heading and description on the first slide, including the grey box when no entry is provided.
    Many Thanks
    Robert
  2. Yogesh
    Yogesh Guest
    .slide .slide-content.entry {
    It will resolve your issue.
    Yogesh Bhade
    jezbellkid likes this.
  3. salliealain
    salliealain New Member
    Hi that's good, but now you can't click on the image to get to the link... what can be done? Thanks
  4. Yogesh
    Yogesh Guest
    That link is word for that slider heading, now you have remove that so how can the link will work ?
    If you want to use that link then you have to display that slider description.
    Yogesh Bhade
  5. rlculver
    rlculver New Member
    Thanks.
    I see this removes it from all the sliders. Can we remove from just the first one?
    Many Thanks
  6. Yogesh
    Yogesh Guest
    If you want to remove slider description from first slider then you have to edit in code.
    If you want to do this change in code please do some steps as shown below in screenshot.
    Yogesh Bhade
