Remove Slider Heading and/or Descriptions
Discussion in 'Compass WordPress Theme' started by vibrandsee, Oct 21, 2016.
  1. vibrandsee
    vibrandsee Member
    1) How do I remove the slider heading and/or description.
    2) How do I change the font colour / background colour of the slider heading and description (should I choose to keep the slider headings and descriptions).
  2. Naveen
    1) To remove the slider caption, you need to paste below CSS code in Custom CSS field located in Dashboard->InkThemes->Theme Options->Styling Options
    .salesdetails {
    2) To change the color of slider caption heading and description, you need to paste below CSS code in Custom CSS field located in Dashboard->InkThemes->Theme Options->Styling Options
    .sl-slide-inner h1{
    color:#eee;
    .sl-slide-inner p{
    color:#eee;
    You can either keep the caption or remove it but, you won't be able to keep it for your desired slider image. That needs a source code modification.
    I hope you understand,
    Warm Regards!
    Naveen Kolhe
