Remove slider navigation and space
Discussion in 'Appointway WordPress Theme' started by v4sb, Feb 9, 2015.
  1. v4sb
    v4sb Member
    Is there a way to remove the slider navigation and remove the space that will be left over once this is done?
  2. Yogesh
    Yogesh Guest
    .flex-direction-nav, .flex-pauseplay {
    It will resolve your issue.
    Yogesh Bhade
  3. v4sb
    v4sb Member
    Thank you. That worked; however, there is space left over after applying this. Is there anyway to reduce this space (between the slider and the three-feature area)? Thank you. By the way, you guys are great. I really appreciate your support.
  4. praveen
    praveen Support Staff
    .featurebox {
    margin-top: -15px;
    .featurebox .featurebox_wrapper {
    padding-top: 10px;
    margin-top: -15px;
    Praveen
