Remove Tap to Call feature and
Discussion in 'Infoway WordPress Theme' started by bizgirl, May 19, 2017.
  1. bizgirl
    bizgirl Member
    Hi there
    Can you please tell me how to remove the tap to call feature. My client is not happy with how it looks on mobile as the button with phone number takes up too much space.
    Is is also possible to remove the Contact Us button from the top menu (right hand side as shown on www.maroochydoreroos.com)
    Cheers,
    Maggie
  2. Naveen
    Hello Maggie,
    For this, you need to paste the below custom CSS code in the Custom CSS field located under Dashboard->InkThemes->Theme Options->Styling Settings
    .siteinfourl a,
    .siteinfourl a p {
    @media only screen and (max-width: 767px){
    .taptocall {
    This will help you to figure it out and resolve your issue(s).
    Regards!
    Naveen Kolhe
  3. bizgirl
    bizgirl Member
    Hi Naveen,
    It seems to have changed on my computer but when browsing on my galaxy mobile it is still showing both Contact Us and the Phone no 0408400999.
    Could you please check on your phone whether this is the case. I have cleared the browsing history etc on my phone but it is still showing.
    Your help is greatly appreciated as always.
    Cheers
    Maggie
    smith likes this.
  4. Naveen
    Hello Maggie,
    I've just checked it in my mobile, but didn't get it.
    It's working.
    Please check again after clearing your browser's cache.
    Regards!
    Naveen Kolhe
    smith likes this.
  5. bizgirl
    bizgirl Member
    Many thanks Naveen. Is there some code to increase the size of the website on mobile
    so it appears larger, even if it means not showing much of the background image?
    Cheers,
    Maggie
  6. nitin
    nitin Guest
    Hi Maggie,
    To increase the width of the content, just use the custom CSS code given below:-
    .container_24 {
        width: 420px;
    .body_wrapper {
        width: 420px;
    Hope this helps...!
    Nitin
    smith likes this.
  7. bizgirl
    bizgirl Member
    Thank you so much Nitin...have a great week!
    smith likes this.
