I installed Bizway with Yoast SEO already installed. I got a notice of a incompatability issue because Bizway blocks meta tags. I allowed Yoast to fix the issue. Here is the note I received: Removed hardcoded meta description Will this interfere with the theme in any way? thanks.
Hello, Go to the header.php file present in your theme directory and follow the instruction shown in the image given below. This will remove the meta description code from the theme.
