Removing Address From Display
Discussion in 'ClassiCraft WordPress Theme' started by amaconline, Sep 12, 2013.
  1. amaconline
    amaconline Member
    Thank you first of all for all your support. For security we would like to hide/remove address from displaying that display with each ad. Check attachment for your ref.
    Thank you.
    Eastern Globe
    www.EasternGlobe.com
    Go to single-ad.php present in your theme directorye and remove the code given below
        <table class="ar_desc">
                                                    <?php
                                                    $free_ad = get_post_meta($post->ID, 'cc_add_type', true);
                                                    foreach ($cc_custom_meta as $field) {
                                                        if (($free_ad == "pro") || ($free_ad == "free" && $field['show_free'] == true)) {
                                                            if ($field['type'] != 'image_uploader' && $field['type'] != 'cc_map_input' && $field['type'] != 'cc_map' && $field['htmlvar_name'] != 'cc_price' && get_post_meta($post->ID, $field['htmlvar_name'], true)) {
        <tr>
        <td class="label"><?php echo $field['field_title']; ?></td>
        <td><?php echo get_post_meta($post->ID, $field['htmlvar_name'], true); ?></td>
        </tr>
        <?php
                                                </table>
    Sending image for reference
    amaconline likes this.
  3. amaconline
    amaconline Member
    Hi Gourav, Thank you very much. However, is it possible to hide just the:
    • Street Address
    • Post Code
    Thank you.
  4. amaconline
    amaconline Member
    Is there any solution for the above. Please check my last post. Thank you very much.
  5. Piyush
    If this isn't something you're able to do then you would need to hire Freelancer for this.
  6. amaconline
    amaconline Member
    Temporarily I have managed to set the "Active" option to "No" on Settings --> Custom Field just for the "Street". I really hope you will update another option under setting so user can decide whether the address should display partly or as a whole.
    Thank you for your help any way.
