Removing Breadcrumbs
Discussion in 'ColorWay WordPress Theme' started by 1stopnonprofitshop, Mar 21, 2016.
  1. 1stopnonprofitshop
    1stopnonprofitshop Guest
    Can you remove the breadcrumbs at the top of the site? Image attached.
  2. nitin
    nitin Guest
    To remove the breadcrumbs, just paste the code given below in Custom CSS section
    div#crumbs {
    Hope this helps...!
    Nitin
