Removing dates on posts...
Discussion in 'BlogSpring WordPress Theme.' started by marian, Mar 12, 2014.
  1. marian
    marian New Member
    Is there an option to remove the dates from the posts so that they are not showing?
    And also, I have 2 featured posts on the home page, but they are ordered from the oldest to the newest, so when a visitor enters my site he will see the older featured post at first and just under this post is the latest featured post. I guess the order of featured posts should be from the newest to the oldest ones..
    Thanks for you wonderful support so far!
    Marian
    1. Paste the code given below in Custom CSS section
    .content-bar .post.single ul.post_meta li.posted_date {
    .featured_post .post ul.post_meta li.posted_date {
    This will remove the date from post.
    2. For your second issue,
    go to the index.php file present in your theme directory and follow the instruction shown in the image given below.
    This will display the feature post according to the publish date.
  3. marian
    marian New Member
    wonderful, thanks a lot!
    Marian
