Removing Default Bullets from Widget Sidebar
Discussion in 'Forum Rules' started by itsdyl, May 21, 2015.
  1. itsdyl
    itsdyl New Member
    Hi there,
    Was wondering if anyone could help me remove the default bullet points/icons that appear before the widget heading in the side bar? I'm using the Gammero Pro theme.
    These little ones...[​IMG]???
    Would really appreciate any help. Thanks
  2. sameerwalkar
    sameerwalkar Guest
    Could you please provide you site URL
  3. itsdyl
    itsdyl New Member
  4. itsdyl
    itsdyl New Member
  5. sameerwalkar
    sameerwalkar Guest
    (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard
    .sidebar_wrapper .sidebar .wrap .sidebar_title {
      background: none;
    Hope it will solve your issue.
    Let me know for further doubts.
  6. itsdyl
    itsdyl New Member
    Thank you so much. That worked perfectly.
    One last thing....
    On the front page i have changed the 'feature bg image' to:
    .feature_content .feature .feature_title {
    background:url(images/GG-feature-header-bg.png) no-repeat;
    However when i check the site on my mobile device, it still shows the default background?
    Can you tell me where else i have to change the image in the code to fix this.
    Thanks again. I will definitely be purchasing my themes from you guys in the future.
  7. itsdyl
    itsdyl New Member
    Also for future reference/use of this theme...is it possible to have a different bg image for each feature title section?
    Thanks again.
  8. sameerwalkar
    sameerwalkar Guest
    It seems that you have missed to apply @media in your code.
    Kindly try the below code it should fix your issue:
