Hello, How do I remove the following from the website - http://www.choppershotsimaging.com/newsite/ 1. Setting Up Footer 2. Search 3. Page Archives 4. Contact Us. Thanks
Hello, The area you are talking about is a widget area. To change it go to the Appearance > Widget then drag widget of your choice and drop it in the First, Second, Third and Fourth footer widget area. Widgets will automatically display at the footer area.
