Removing "home" from pages
Discussion in 'Blackriders WordPress Theme' started by filipr, Apr 8, 2014.
  1. filipr
    filipr New Member
    Hi!
    I have this problem where I can´t get rid of "home" in my pages. As seen in the picture.
    I also want to change the language on the buttons, such as the Read more button.
    Go to
    Appearance > Menus
    Create a custom menu and only add the pages that you want to show in the navigation bar.
    2. Go to functions > define_template.php present in your theme directory and follow the instruction as shown in image given below
    Gourav Shrivastava
  3. filipr
    filipr New Member
    Hi again!
    My second issue was solved, thanks!
    But the problem with my first issue is that there is nothing called "home" in the menus. My "hem" is my home. Although they both link back to the homepage.
  4. filipr
    filipr New Member
    I figured it out, I don´t know how but my problem is fixed:)
