Removing Homepage Features
Discussion in 'BizWay WordPress Theme' started by pupwild, Mar 22, 2013.
  1. pupwild
    pupwild Member
    I would like to know how to remove the Homepage Feature sections.
    Paste this code in Custom CSS
    .main-content {
    .main-content-container {
    margin-top: 10px;
    padding-bottom: 0;}
  3. pupwild
    pupwild Member
    Thanks! Now if I remove the homepage features, is any previous text still visible to search engines? For instance, when I do a search on a keyword, will google pull the keyword from my old homepage feature?
  4. Piyush
    Yes, google will pull the keyword from your homepage feature if any one search on it for this keyword.
    If you want to hide your home page feature content from the google search then you have to follow the steps given below.
    1. Go to the front-page.php file present in your theme directory.
    2. Remove the code given below from the line number 190 t0 260 of front-page.php file.
    <div class="main-content">
        <div class="grid_sub_8 sub_alpha">
        <div class="page-item first-item view view-ninth">
        <?php if (inkthemes_get_option('inkthemes_firsthead') != '') { ?>
            <a href="<?php echo inkthemes_get_option('inkthemes_link1'); ?>"><h1><?php echo stripslashes(inkthemes_get_option('inkthemes_firsthead')); ?></h1></a>
            <?php } else { ?>
        <a href="#"><h1>We are the future</h1></a>
        <?php } ?>
        <?php if (inkthemes_get_option('inkthemes_featureimg1') != '') { ?>
                <a href="<?php echo inkthemes_get_option('inkthemes_link1'); ?>"><img class="effect" src="<?php echo inkthemes_get_option('inkthemes_featureimg1'); ?>"/></a>
                <div class="mask mask-1"></div>
                        <div class="mask mask-2"></div>
                <?php } else { ?>
        <a href="#"><img class="effect" src="<?php echo get_template_directory_uri(); ?>/images/img1.png" /></a>
        <?php } ?>
          <?php if (inkthemes_get_option('inkthemes_firstdesc') != '') { ?>
                        <p><?php echo stripslashes(inkthemes_get_option('inkthemes_firstdesc')); ?></p>
                    <?php } else { ?>
                        <p>Slider in the Header. It comes different Color Schemes red, green, blue, brown, pink, black, orange. Hello this design comes.</p>
                    <?php } ?>
        </div>
        </div>
        <div class="grid_sub_8 sub_middle">
        <div class="page-item item-two view view-ninth">
        <?php if (inkthemes_get_option('inkthemes_secondhead') != '') { ?>
            <a href="<?php echo inkthemes_get_option('inkthemes_link2'); ?>"><h1><?php echo stripslashes(inkthemes_get_option('inkthemes_secondhead')); ?></h1></a>
            <?php } else { ?>
        <?php } ?>
        <?php if (inkthemes_get_option('inkthemes_featureimg2') != '') { ?>
                <a href="<?php echo inkthemes_get_option('inkthemes_link2'); ?>"><img class="effect" src="<?php echo inkthemes_get_option('inkthemes_featureimg2'); ?>"/></a>
                <?php } else { ?>
        <a href="#"><img class="effect" src="<?php echo get_template_directory_uri(); ?>/images/img2.png" /></a>
        <?php } ?>
          <?php if (inkthemes_get_option('inkthemes_seconddesc') != '') { ?>
                        <p><?php echo stripslashes(inkthemes_get_option('inkthemes_seconddesc')); ?></p>
                    <?php } else { ?>
                    <?php } ?>
        </div>
        </div>
        <div class="grid_sub_8 sub_omega">
        <div class="page-item last-item view view-ninth">
          <?php if (inkthemes_get_option('inkthemes_thirdhead') != '') { ?>
            <a href="<?php echo inkthemes_get_option('inkthemes_link3'); ?>"><h1><?php echo stripslashes(inkthemes_get_option('inkthemes_thirdhead')); ?></h1></a>
            <?php } else { ?>
        <?php } ?>
        <?php if (inkthemes_get_option('inkthemes_featureimg3') != '') { ?>
                <a href="<?php echo inkthemes_get_option('inkthemes_link3'); ?>"><img class="effect" src="<?php echo inkthemes_get_option('inkthemes_featureimg3'); ?>"/></a>
                <?php } else { ?>
        <a href="#"><img class="effect" src="<?php echo get_template_directory_uri(); ?>/images/img3.png" /></a>
        <?php } ?>
          <?php if (inkthemes_get_option('inkthemes_thirddesc') != '') { ?>
                        <p><?php echo stripslashes(inkthemes_get_option('inkthemes_thirddesc')); ?></p>
                    <?php } else { ?>
                    <?php } ?>
        </div>
        </div>
        </div>
    After few days the content of homepage feature of your website will remove automatically from the google search directory.
