Removing Homepage Sections
Discussion in 'Blackriders WordPress Theme' started by tpsarkis, Dec 12, 2017.
  1. tpsarkis
    tpsarkis Member
    I'd like to remove the homepage feature and the blog section on the homepage and just have the H1 title and a section below rto add an article if needed.
    Maybe the possibility of removing the footer section later on because the page will be used for advertising primarily so having less on it mich be better for mobile devices.
    Please let me know how to do this.
  2. akbar92
    To remove those sections, just paste the code given below in Custom CSS section.
    .home-content {
    .bottom_feature .col-md-8.col-sm-8 {
    .bottom_feature .col-md-4.col-sm-4 {
    Hope this helps...!
    Akbar
  3. tpsarkis
    tpsarkis Member
    Hi, not quite what I'm asking.
  4. tpsarkis
    tpsarkis Member
    I want to leave the Title in the content section and the area just below it to add content.
    The section wiotht eh round thingys and all below that is what I want to remove.
    I don't want to remove everything.
    Please let me know if you're still not sure what I'm asking.
  5. tpsarkis
    tpsarkis Member
    I will take a screenshot with arrows so that you don't get confused with my request
  6. tpsarkis
    tpsarkis Member
    I need to remove everything BELOW the red line in the photo, inluding the Blog post section below it.
    I would also like to know if it's possible to remove the default FOOTER sections without having to add my own.
  7. akbar92
    Please use below-given codes:
    .feature_box {
    .bottom_feature .blog-heading {
    .bottom_feature .blog_feature {
    .bottom_feature .sidebar.home {
    There are two solutions to remove footer widget area:
    1: To completely remove footer widget area, just paste the code given below in Custom CSS section.
    .footer_container {
    2. To remove only text and widgets, just place the blank text widget in the widget area,
    (Dashboard->Appearence->Widgets)
    Hope this helps...!
    Thanks & Regards,
    Akbar
  8. tpsarkis
    tpsarkis Member
    Thank you very very much Akbar.:)
  9. akbar92
