I'm using the Events Calendar Plugin. It made a new page for upcoming events, but it is showing the right sidebar widget. Normally, when I create a new page, I have the option to do full screen and it gets rid of this sidebar. On this page, it doesn't give me that option. How do I get rid of the sidebar? http://theme1.1stopnonprofitshop.com/event/test-event-1/
Hi, Greetings from InkThemes, I would like to let you know that you can do this, by assigning a template to the concerned pages. To do this, just open the page in edit mode and select the 'Fullwidth Template' from the list of Templates on the right (as shown in the screenshot below) Hope this helps...! Thanks & Regards! Nitin InkThemes.com
That's what I usually do when creating a new page...but for some reason...when creating a page through the Events plugin, the Page Attributes aren't an option.
Hope you are doing good....! I really appreciate your efforts in exploring the things and sharing your knowledge here. It seems that you have resolved your issue by your own. Let me know if you have further doubts so that I can assist you. Thanks & Regards! Nitin InkThemes.com
