Removing Sign up and Blog on Home Page
Discussion in 'GoldenEagle WordPress Theme' started by landitollig, Feb 28, 2014.
  1. landitollig
    landitollig New Member
    Good day,
    I am building a website on the Golden Eagle Template.
    On the Home Page there is a Sign up part/bar and a part below that where blog posts/widget shows.
    How do I remove both of these?
    I did make a static home page at set that right in my General Settings.
    I attached a screenshots. (1 is from the template. 2 is how mine looks at the moment.)
    Thank you!
    Landi
    .feature-strip {
    .feature-blog {
    .feature-bottom {
  3. taasvik
    taasvik New Member
    Thank you, I used the same method to get rid of the top search button :) But I would like to get rid of the dashed line at the top as well - how do I do that?
  4. Piyush
     .social-links {
    border-bottom: none;
    This will remove the dashed line from the top.
