Removing the areas in red from post pages?
Discussion in 'Infoway WordPress Theme' started by bernz, Apr 18, 2013.
  1. bernz
    bernz Guest
    I am attempting to remove the side and bottom areas in my post. I am attaching a screen shoot so that you can view what I am attempting to remove. The link is (http://www.harmonymhbs.com/?p=39).
    Thank you,
    Ben
    Hello Ben,
    For this
    Go to the Appearance > Editor, Open single.php and remove code as shown in the image given below.
  3. bernz
    bernz Guest
    Will this work if I want the side information removed if I add a page instead of a post?
  4. Nitesh
    Hello Ben,
    Solution above can only remove sidebar from single page.
    To remove sidebar from all pages
    Paste this code in Custom CSS
    .sidebar{
    display:none;}
  5. bernz
    bernz Guest
    That worked, but know I have a lot of white space to the right of my image and text. how do I flow the text freely in those/that area so there is no white space?
    I have included a link so that you can see can get an visual of what I am referring to.
    http://www.harmonymhbs.com/?page_id=73
    Thank you
  6. Nitesh
    Edit this page and select fullwidth-page template for it.
    Check image for reference.
  7. bernz
    bernz Guest
    Another question on the white space that's left open when I remove the text from the side area, is there a way to add graphics in that area? If so how?
    Thank you,
    Bernard
  8. Nitesh
    Hello Bernard,
    You can add images through "text widget" in sidebar widget.
    Go to the Appearance > Widget
    drag text widget and drop it in the primary, secondary sidebar widget area.
    Then add code given below in it.
    <a href="your link address"><img src="your image address"></a>
