Rental Pro Theme
Discussion in 'General InkThemes Discussion and Feedback' started by rtsgdr, Sep 5, 2018.
Tags:
  1. rtsgdr
    rtsgdr New Member
    I have uploaded the theme. however I am not able to change the default front page. I like to put images in the template as it just show sizes. I see a phone number on the top which I cannot change. Also the footer has a lot of unrelated information which I like to remove. All it lets me do is change the menu!!!
  2. akbar92
    You can edit homepage content from Theme Options, Go to (Dashboard->Appearence->Theme Options )
    You can change it from your website dashboard, Go to (Dashboard->Appearence->Theme Options, General Settings). Please have a look at the attached screenshot (phone-no).
    You can change the footer content from the First, Second, Third and Fourth footer widget area. Please have a look at the attached screenshot (widget-area).
    I hope you find the above information worthwhile for you.
    Akbar
  3. rtsgdr
    rtsgdr New Member
    Thanks for the information.
    we like the default front page template which you have. We are trying to add/revise the pictures to it and it does not allow us. Can we use this for our front page? If so how do we edit this template?
    Thanks in advance.
  4. akbar92
    It seems like you want to install the theme demo content on your website.
    To install the theme demo content, Just visit your members area: https://www.inkthemes.com/members/member
    Get download the zip file of your theme along with JSON and XML files.
    Now, visit your WordPress Dashboard->Appearance->Themes->Add New->Upload
    Upload & activate the theme and also install the Ink Import Export plugin.
    By using our import export plugin, you can upload the demo contents (XML and JSON).
    I hope you find the above information helpful.
    If you still unable to install demo content then just send the below-mentioned credential details at [email protected] along with the thread link.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do it for you.
    Regards!
    Akbar
  5. rtsgdr
    rtsgdr New Member
    Hello Again
    How do I remove the footer saying home builder and change the phone number on top right hand corner in the default homepage? I have attached screenshots.
    Thank you
      File size:
      127.2 KB
      3
      File size:
      35 KB
      3
  6. akbar92
    To remove that, just place the blank text widget in the widget area,
    (Dashboard->Appearence->Widgets)
    And to change that, just place any widget in the Fourth Footer Widget Area.
    To change the phone number, Go to (Dashboard->Appearence->Theme Options->General Settings-> Custom CSS) just follow the attached screenshot.
    Hope this helps...!
    Thanks & Regards,
    Akbar
  7. rtsgdr
    rtsgdr New Member
    Thank you for help.
    I have got the footer section figured out. Thank you
    On the header where the image of phone number is, I have followed your suggestion and entered the phone number. But it does not show and/or replace the number which is in the template..
    The same is true with the business logo on the left of the number.
    How do I get rid of the phone number that is on top and replace the logo?
    thanks
  8. akbar92
    TO remove the phone number, just paste the code given below in the Custom CSS section.
    (Dashboard->Appearence->Theme Options ->Styling Options-> Custom CSS) of your dashboard.
    .header_wrapper .logo_wrapper .logo {
    To change the logo, go to (Dashboard->Inkthemes->Theme Options -> General Settings-> Custom CSS). Please have a look at the attached screenshot.
    I hope you find the above information helpful to you.
    If the problem still persists then just share the WordPress admin credentials of your website at [email protected].
    Akbar
  9. rtsgdr
    rtsgdr New Member
    Sorry to bother.
    Please see the attached screen shot. I believe I have followed you instructions for removing the default phone th.jpg number, but I do not see the section you are referring to to insert the code you provide.
    Please help
    thanks
  10. akbar92
    Greeting from InkThemes,
    To make the desired changes, just paste the code in the custom CSS section of the theme.
    Go to (Dashboard->InkThemes->Theme Options->Styling Options->Custom CSS).
    Akbar
  11. rtsgdr
    rtsgdr New Member
    Thank you again. I followed your suggestion and still no change!
    Please look at attachment
  12. akbar92
    To change the logo just see the video link I am attaching along with this thread.
    Just have a look at it: https://screenpresso.com/=JBjnf
    To remove the Contact number, just paste the code in the Additional CSS section of the theme.
    Go to (Dashboard->Appearance->Customize->Additional CSS).
    .header .header_info img {
    Akbar
  13. rtsgdr
    rtsgdr New Member
    Sorry to bother again.
    I did put the code where you suggested and still NO Hope!!!
    Is it possible that I can give you the login info to you so it can get fixed?
    That way I will be thankful and will quit bothering you.
    these two are the only issue we have to get our site going.
    Thank you
  14. akbar92
    Okay, then kindly send the below-mentioned credential details at [email protected] along with the thread link.
    We will do the needful.
    Akbar
  15. jefe777
    jefe777 New Member
    How can I update the captcha in the Contact Us feature in RentalPro? The theme comes with the outdated reCAPTCHA V1. I've been to g.co/recaptcha/upgrade and it wasn't particular helpful.
    Also, how do I adjust the settings for the Contact Us feature. I'm not receiving message at the site Admin's address. How do I know where this is sending?
    Jeff
  16. jefe777
    jefe777 New Member
    How do I change the field labels in Property pages? Instead of the label "Bed rooms" I'm getting the label "BHK". Please see attachment. What is "BHK"? Why is displaying? How can I change this?
    Thanks for your assistance,
    Jeff
  17. akbar92
    We will need to do some of the changes in the coding for getting the required changes which you are asking for.
    Just send the string which you want to place in place of BHK.
    Akbar
  18. jefe777
    jefe777 New Member
    Just sent email with access details. Thank you.
  19. akbar92
    We have successfully received your credentials and will start working soon.
    As we are done we will let you know.
    Till then I will request you to be patient.
    We will follow you up using the Emails.
    Akbar
  20. jefe777
    jefe777 New Member
    Using the gallery function, the images are rendering stacked on top of one another and on top of other blocks. This only happens on iPad using Safari. This web page is: http://alfredrental.com/index.php/2018/12/03/the-village-center-at-38-north-main-street/. Can you offer me some assistance on how to prevent this from happening? I've spent several hours trying to fix this with different iterations of galleries and html.
    Jeff
