replace front page blog with text
Discussion in 'ColorWay WordPress Theme' started by smarta, Feb 17, 2017.
  1. smarta
    smarta Member
    hi
    I want to change the front page so that the text area goes full width and replaces the Blog section
    I've done it before with this site http://amarco-iluka.com.au/ but don't remember how I did it!
    I want to change this site http://smartawordpress.com/ to the same layout
  2. Naveen
    Hello Smarta,
    For your information, the design changes in the theme require some code customization, we can do it for you,
    Kindly, share your WordPress admin credentials at [email protected] along with this thread URL:
    WordPress site login URL:
    WordPress admin username:
    WordPress admin password:
    I will check and do the needful.
    Warm Regards!
    Naveen Kolhe
  3. smarta
    smarta Member
    ok _ sent the email with the log-in
  4. smarta
    smarta Member
    I am also trying to use the plug-in "The Sticky Menu (Or Anything) On Scroll "
    https://en-au.wordpress.org/plugins/sticky-menu-or-anything-on-scroll/
    I have created a menu in the site options called "menu 1"
    when I use the settings to control what is "sticky" I put Menu 1 but does not work
    I have also tried ddsmoothmenu, main-menu etc but still it does not work
    can you suggest what I should put there - or can you suggest a better plug-in
  5. smarta
    smarta Member
    ok - I worked out the sticky menu - I used .header
  6. smarta
    smarta Member
    I now want to make the background a darker grey - whats the css for that ?
  7. nitin
    nitin Guest
    To change the background color, just paste the code given below in Custom CSS section
    body.compass_theme {
        background: #757575 !important;
    Note:- The above value for the color code is the one that is presently set in your theme, please change the values accordingly
    Hope this helps...!
    Nitin
  8. smarta
    smarta Member
    thank you but can you attend to my original question
    I have emailed log-in info
  9. nitin
    nitin Guest
    Hope you are doing good...!
    You would be glad to know that we have made the required changes to your website as per your requirements.
    Kindly check and acknowledge us for the same.
    Nitin
  10. smarta
    smarta Member
    thanks
