I want to replace the section on the home page that has Social Links Email - [email protected] Call Now - 1234 -000 -548 with a block of text - I am guessing I could use either a widget or I could put it as html into the template file what would you suggest?
Hello, Greetings from InkThemes! Yes, you can easily replace that section through widget area by following the steps as mention in the video (given below) Link of the video: http://screenpresso.com/=SMHKf Hope it will resolve your issue Thanks & Regards! Priyanka Inkthemes.com
hi Priyanka sorry that did not do what I wanted see here http://uniformsfornetball.com.au/ the text has appeared under the footer and the "Social Links" is still there I wanted to completley replace that line with the multi lines of text (which is now appearing below the footer)
Hello, If you want to replace that part with the text then we need your dashboard access to resolve your issue because that will required some customization. So, send us your website dashboard login details at [email protected] and we will do it for you. If you want to completely remove that part then you can use below CSS code in Custom CSS field (Appearance=>Theme Option=>Styling Option=>Custom CSS) of your Dashboard. Code: .footer-top { display: none; } Thanks & Regards! Priyanka Inkthemes.com
