hi, i want to replace the default mobile menu with a different mobile menu using a plugin. Could you please see the picture i have attached and tell me what should i type in the two boxes. i need to specify the menu container in the first field. Then in the second field, need to specify the actual mobile menu button. thnaks.
Hello, That's is something related to source code customization, just visit header.php you will get the menu function and HTML there. Warm Regards! Naveen Kolhe InkThemes.com
