Replace Slider Heading/Description with Opt-in Code?
Discussion in 'ButterBelly WordPress Theme' started by mkeckler, Feb 27, 2015.
  1. mkeckler
    mkeckler New Member
    I want to use the ButterBelly theme on my site, but would like to have an Opt-In Offer below the slider... Something similar to how http://MichaelHyatt.com uses. Is this possible with a quick tweak or what would you recommend?
  2. praveen
    praveen Support Staff
    Hi mkeckler,
    You can help you to insert a banner image just below the slider but it will be same for all the other slider images.
    Praveen
  3. mkeckler
    mkeckler New Member
    Yes, that would be fine. I'd appreciate the help on how to do it.
  4. Pramod
    Pramod Guest
    Hello !
    You can use code in theme option for each and every image.Go to Appearance=>Theme Options=> Slider Settings=> First slider Heading
    <a href="put your offer link" ><img src="http://www.sinosteel.name/Images/banner_Join_us.jpg" alt="banners1"></a>
    Please put links and image links according to your requirement.Further you can adjust image through CSS code.
    Pramod Patel
  5. mkeckler
    mkeckler New Member
    Thank you! I'll try that. What size image do you suggest?
  6. Pramod
    Pramod Guest
    Hello mkeckler!
    You can use near to 1000pxX250px dimension image.
    Further you can adjust by CSS.
    Pramod Patel
